Scat 84mm crankshaft - Type 4 centre main bearing, all other T1
flange type flywheel mount- the strongest possible
Chevy connecting rod journal - 2 inch- 50.8mm (VW is 55)
Main bearings are .50mm undersize and rod journal is 0.25mm
Mains need polishing and rod journals need grinding
This crankshaft costs $1800 new and is now for sale for $800 ( 2800zl )
This can be used in standard VW engine, but the back of the case will need to be opened to 101.75mm to accept flange.
This crankshaft will give 2332cc with a 94mm piston
