Seryjne korby mozna by zastosowac w kazdum silniku w polsce pomijajac dlugosc, problemem jest ich niewiadomy stan (zwlaszcza srubek). Koszty regeneracji korb sa porownywalne z i-beam'ami ktore maja srubki arp i sa pewne
How expensive is an engine to run 13s?
czyli ewentualny nowy punkt na liście must buy:) na zimę.
I sa wywazone (waga calosciowa i poszczegolnych koncow)
For clarification, this will be a naturally aspirated engine. I would hope for considerably more than 150hp and 13 seconds from a turbo engine.
The cost limit I set covers parts and machining, not our labour because, I would expect someone else to copy the recipe if they would like to do it themselves. Also, water and electricity is not covered.
I now have a street car in which I can test a 1914 engine. I chose this engine even though I had planned to instal a 2600 T4 because it is more realistic compared to the engines here in Poland. As some of you know, I now have a 1303, which is bit heavier than most Beetles and so it will need a bit more power to run 13s. It will also have a full interior and run the gearbox than was originally in our Fiat 126- a standard 1303S gearbox with a Quaife LSD. This gearbox is not ideal for drag raging beause of the long gears, but the car is intened for high speed cruising so it is best for that. I hope to get at least 160hp and if it all goes well maybe 170hp from it, which should be enough to put it into the 13 second zone. I might get Pati (my girl) to drive to help with weight aspect
, but the car will be in full street trim (no slicks etc).
chris burns napisał(a):I now have a street car in which I can test a 1914 engine. I chose this engine even though I had planned to instal a 2600 T4 because it is more realistic compared to the engines here in Poland. As some of you know, I now have a 1303, which is bit heavier than most Beetles and so it will need a bit more power to run 13s. It will also have a full interior and run the gearbox than was originally in our Fiat 126- a standard 1303S gearbox with a Quaife LSD. This gearbox is not ideal for drag raging beause of the long gears, but the car is intened for high speed cruising so it is best for that. I hope to get at least 160hp and if it all goes well maybe 170hp from it, which should be enough to put it into the 13 second zone. I might get Pati (my girl) to drive to help with weight aspect, but the car will be in full street trim (no slicks etc).
Looking forward to see it on the strip
A Ty Chris cały czas o tej wadze mówisz
