MadaFaker
30 kwietnia 2007, 22:32
The compression is low (ish).I would have given it more if it had been for me or for a race car. This about right for the camshaft that Renifer is using. I have built road engines with 11:1 but with much bigger camshafts.
As to Scat lifters, I know that they have had a bad rep, but I have not lost any yet. A close friend of mine tried many different types of follower in his engine (about 6 in total and they all died). They were Scat, CB, standard, some exotic German ones etc. I feel that you should use a camshaft and lifters from the same manufacturer with the only exception being ceramic.
30 kwietnia 2007, 22:34
Falco- I know you didn't ask about the engine, but Arek did.
30 kwietnia 2007, 23:00
chris burns napisał(a):The compression is low (ish).I would have given it more if it had been for me or for a race car. This about right for the camshaft that Renifer is using. I have built road engines with 11:1 but with much bigger camshafts.
Ja prosiłem o mniejszą ok. 8, więc będzie pewnie słabyszy.
Właśnie z powodu tej opinii prosiłem o zmiane popychaczy na CB 28 hd, czy cos takiego, choc to moze tylko opinia, bo Steve tez standardowo w ofercie ma popychacze scata. Co do walu, to to raczej nie bedzie scat.
http://www.thesamba.com/vw/classifieds/detail.php?id=270355
lub niestety ten
http://www.thesamba.com/vw/classifieds/detail.php?id=111062
A jaki wydech ma Renifer?
Chris, słyszałes moze kiedys garba z wydechem a1 sidewinder?
Chodzi mi o wrazenia wokalne.
30 kwietnia 2007, 23:05
Whyshchuck napisał(a):Falco, bardzo mi przykro, ale to sie nazywa egotyzm.
słucham...?
(Po)zdrówka!falco
30 kwietnia 2007, 23:06
chris burns napisał(a):Falco- I know you didn't ask about the engine, but Arek did.
ups... It's Ok! ;)
Best regards
(Po)zdrówka!falco
30 kwietnia 2007, 23:19
Whyshchuck napisał(a):Właśnie zrozumiałeś :-)
ups... It's Ok! too. ;)
(Po)zdrówka!falco
30 kwietnia 2007, 23:33
falco napisał(a):
Renifer napisał(a):Więc mam juz swojego MadaFakera (2165 cc). :D
H!
Gratuluję wyczekiwanego "dziecka"! ;)
A teraz powiedz jakie masz heble, zawias, stan budy, bo (nic osobistego), ale zazwyczaj tuning w PL zaczyna się od du...py strony, czyli...
- nieważne jak/czy w ogóle Garb 3ma sie ku...py,
- nieważne czy zahamuje,
- ważne aby ruszyć z kopyta...
Serducho, to sama kwintesencja, ale ja uważam, że takie "potwory", powinno się zaczynać budować od mocnej, zdrowej karoserii, wytrzymałego zawieszenia, skutecznych hamulców. Na koniec montując "pompkę".
O innych "detalach" nie wspominam, ale ile jest tak zrobionych Garbów, to na palcach...
Jak u Ciebie...?
Nie zgodze się z toba, ja w swoim zacząłem od hamulców, jak dobrze się rozeznaję a opinię tą potwierdził Qucu, Renek tez od razu hamulce zrobił. blachę w sumie tez ostatnio robił, więc nie ma się co czepiać :D Każdy z nas najbardziej skupia się na silniku, ale dba i o resztę :D
30 kwietnia 2007, 23:39
Majki napisał(a): Nie zgodze się z toba, ja w swoim zacząłem od hamulców... :D
ale z czym się nie zgadzasz?
To, że podałeś swój przykład, to niewiele zmienia, znam "trochę" więcej autek... :P
(Po)zdrówka!falco
30 kwietnia 2007, 23:42
lub niestety ten
nie wiem co chcez od walu CB... sa to na prawde spoko waly... i prawde mowiac wolalbym miec CB jak Bug packa czy DPR...
a o serrano... sorry nie wypowiadam sie...
ale to ne toic na to... nie schodzmy OT.. .tu sie mowi o potworze Reniego...
Spoko ziom ze sie nacieszysz :) tylko nie zajezdzij go od razu... :) rob tak jak ci chopaki z Chrisem na czele powiedza a pojezdzisz zluuugo i szczesliwie.
Powodzenia...
30 kwietnia 2007, 23:45
a właśnie, że zmienia bo widac, ze idziemy wszyscy z dobrym kierunku :wink:
www.cal-look.pl
www.locobandito.blogspot.com
30 kwietnia 2007, 23:49
Sam zaproponował mi zmianę, ale musiałbym jeszcze dłużej czekać.
Ten cb jest made in china. moze dlatego.
ale sam zainteresowany milczy. Pewnie nie moze sie nacieszyc i dzisaj bedzie spal w garazu :-D
ej i ja sie podlacze pod Qca i Majkiego :P no i Reniego poniekad :) niby wsadzilem silnik ale tuz za chwilke zrobilem cala reszte (choc po strarosci ze tak powiem nie bylo najgorzej :) )
ej Falco i co z tym Bro Ziom... ;)
30 kwietnia 2007, 23:52
Qcyk napisał(a):a właśnie, że zmienia bo widac, ze idziemy wszyscy z dobrym kierunku :wink:
Majki (chyb) sam z siebie na to "wpadł", ale Tobie to trzeba ł_o_p_a_t_ą do łba kłaść!!! :D:D:D
I tak 3mać! ;)
(Po)zdrówka!falco
30 kwietnia 2007, 23:55
Zielony TYKA napisał(a):ej i ja sie podlacze pod Qca i Majkiego :P no i Reniego poniekad :)
hehehehe uderz w stół, ale ja (nie) tylko Was mam na myśli, prawdę mówiąc, to także naszych południowych sąsiadów, gdzie widywałem Potwora na... garbusowych bębnach pozostawionego... NaTenPrzykład prosto z brzegu. ;)
ej Tykers, jak właśnie łykam, ale to Ty miałeś do mnie zajechać, chyba, że ja o czymś nie wiem... ;) (OT)
(Po)zdrówka!falco
